Hi, I have my SGS2 already over a year and at purchase I installed a 32 GB sd card. But, and this is really stupid, I never checked into the sd card issue when I move stuff to my sd card, I always thought that it was moved to the external card. Now yesterday I try to move some apps using app2sd and I get the message that no sd card is present. And all apps I had moved before were gone. Under the notifications I see "blank sd card" and I select the option to format. This was done in a flash, and from there on app2sd found the sd card. After the format, the contents of my /mnt/sdcard was unchanged. Today used my astro to browse around, and I found a /mnt/sdcard and a /sdcard (there is also a /usb which is empty), both containing, I assume the same files and folders and with a 12 GB size.
When I go to settings - storage, I see an empty 29 GB sdcard, and a 12 GB usb storage.
So, apparently the 32 GB sd card is there. How do I however access it, and is it possible to move apps to the external sd card?
Today, same issue with apps2sd, no card found.
I don't understand what is going on, any help is greatly appreciated.
