Help external sdcard memory not showing in widget
nebler
Hi, I have tried a few different system info widgets and none of them show the correct amount of storage I have left in my memory card. They just say the same amount as my internal memory.
If I look in settings it show the correct amount.
Anyone recommend a widget that works?
I use Eixir Widgets and it allows to provide a path for external memory.
mnt\extSdCard\ works fine.
