I'm running my Cliq with all the widgets gone but somehow motoblur is still running and eating up my battery
I also have about 107 applications loaded... the baby runs great! though! no lag or delay.... my only complaint is the battery life... or lack of....
I bought an extra generic "Cliq compatible" charger on ebay but it did funny things when I plugged it in... the touch screen went crazy... happened twice so I figured that was enough...
not sure if it was a bad charger or what but when I looked close it was 5v at 500mA and the OEM charger is 5.1V at 850mA. The charger still should have worked but if you're getting an extra charger don't take any chances. make sure to get one that's 850mA.
I just ordered Motorola #SPN5358A from ebay for like $7 instead of $19
Good luck!! Lovin' the Cliq!!
