Extreme battery drain
ClaytonD97
My battery is draining EXTREMELY fast at seemingly random times. I attached a screenshot of what's happening. Please help!
Have you checked your screen timeout settings to make sure it's not too high? Also how is the brightness set, having this too high and a high screen timeout setting will murder any battery?
Screen timeout is set to 1 minute and brightness is on auto. It functions as normal , and then all of a sudden it drops to "Critical Levels" within a minute or so
If the situation doesn't change after a factory reset, it could be the battery that needs to be replaced.
