How do you actually comment and rate an application on the marketplace? Whenever I download an app and like it, I would like to rate it, and comment on it, but I don't see that option on the marketplace.
Go into your downloads, select the app you wish to rate, at the top of the page, there is a section called "My Review" where you can give it the number of stars you wish. Once you rate it, you can also write up a review.
go to the app on the market and at the very top you will see stars to rate it. After you rate it, press "post a comment" if you want to write something.
Click "menu" then "Downloads" for all your apps you have
