Extweaks Help
robinta
After an unsatisying time on some 4.1 and 4.2 roms I've gone back to ICS. root box 1.8 with Dream kernel 3.74 on my i19100 S2.
However I can't change any settings in extweaks. Well I can change and save them but as soon as I exit the app they go back to default. It was newver an issue before with this rom/kernel combo. I've made sure any conflicting apps are unistalled. I've cleared caches, reflashed, fixed permissions, cleared init.d scripts everything I can think of. I've even uninstalled the app and pro key and reinstalled to no avail. All I can do is choose the profile in recovery. But can't change anything else. I used to use extweaks and dream to UV successfully. Any one any clues, I'm baffled !
