Face of Ring - phone orientation vs Ring
romario13
Hi all,
There is a small application in the market "Face of Ring". I am an author. Please use it for free and give me your feedback. Thanks.
This is description from the market:
App can turn off ring vibration while phone is positioned horizontally. When you have a meeting, put the phone face down to turn off its ringing. Soft vibration informs you about a call. Turn over it to check caller identity and place the phone face down again if desired.
http://sites.google.com/site/faceofring/Home
Enjoy!
There is new version 1.3.0.
- improved user interface for main screen. Thanks to great UI designer Unguided (http://www.unguided.ru)
- bug fixed: some times state is not changed.
1.2.1
- smoothing the data of sensors when vibration or a loud sound exists
- precise definition of orientation when the phone was turned over if screen is off
- battery life issue: there is no activity when the screen is off
- horizontal layout fixed
1.1.0
- No new features
- Help and minimum settings were added.
1.0.0
- First public release.
ajaredic, the fixed version is available now.
1.5.2
- fix: forceclose on start (Many thanks to Phil!).
1.5.1
- Out of \ In service signal notification (ex. phone in dead zone)
- New preference layout
1.4.0
- Improved algorithm of recognizing phone orientation at start of ringing
- Added capability to mute all other sounds. Please read Note in the Help.
I tried the "out of service" feature ... I heard the alert .... but if I had not been paying attention I would have missed it ... There should be an Alert in the Notification Bar for Lost and then for regain it should clear the alert ... and possibly log the date and time of the outage with a total duration of loss of service ...
Even more fancy would the last know cell tower ID ...
justjimjpc, out of service is not primary feature of the app. If you want it, please use "No Signal Alert" application. In Face of Ring app this feature was implemented in a minimum mode :) And i don't see any reason to repeat whole "No Signal Alert" functionality.
Best Regards
Roman
justjimjpc, out of service is not primary feature of an app. If you want it, please use "No Signal Alert" application. In Face of Ring app this feature was implemented in a minimum mode :o) And i don't see any reason to repeat whole "No Signal Alert" functions.
Best Regards
Roman
Too Bad !!!
> Too Bad !!!
- You can change the rington of alerts
- You can see other "out of service" icon notification on the top right corner (near the battery icon) :)
- If you need to know "How long i am in the dead zone?" and it really helps you - there is "No Signal Alert" for your suit
But current feature is enough functionality for me and i think for 80% of users.
You can choose.
This is too Good !!!
