I'm sure everyone here knows that Facebook sometimes doesn't sync with your newly aquired ROM. For me, it never did. I found a solution however. It may work for you, may not, but this is the best looking solution so far. Discusssed it with others over at XDA and this is what we came up with.
First log into your facebook from the web
On the top right hand side on facebook you will see ACCOUNT
Click on Account and select APPLICATION SETTINGS
Then on the application settings page there will be a drop down box with the title Show: select AUTHORIZE
Then you will have a page with your authorized applications. They are organized by category so you might have to click on the category to expand that section.
In the APPLICATIONS ON FACEBOOK category there will be FACEBOOK FOR ANDROID.
You might have several listings for Facebook for Android. On the far right of the row there is a X.
Click on the X and click REMOVE on the popup.
Do this for every listing of Facebook For Android
Next go to the category DESKTOP APPLICATION.
You will see an entry or entries for HTC SENSE
On the far right of the row of HTC Sense there will be a X
Click on the X and select REMOVE on the popup.
Do this for every listing of HTC Sense
Then go into your phone and re-setup the accounts.
good luck![Cool :cool: :cool:](/styles/smilies/google/cool.png)
good luck
