Help fact reset
duiksmurf
hi
due to repeating battery issues (depletion now in 8 hours without actual using it) I will try a fact reset and start over :-( Battery Power Usage is still only showing:
- Android OS and
- Phone Idle
as major power consumers
Is there an easy way to save my app list?
i am hesitating using my MyBackUp backups due to the fact that this may also restore my problems ...
what proces would you advice?
regards
D.
Your apps are synced to your google account so they should redownload themselves when you sign back in to your google account anyway.
You can backup SMS via SMS Backup & Restore too.
What about contacts? Do you know if they're phone/SIM or if they're stored on the cloud?
What else do you want backed up?
What I would have liked ... yes would have :-(
As you said quite right: most apps are synced and reload themselves after the factory reset. Too bad all settings are lost :-(
I also used MyBackup Pro ... which also only works partially.
short summary:
contacts and calendars are restored
WiFi WEP keys are restored
email accounts are lost (settings lost, mails still availible due to IMAP)
sms are lost - restored via mybackup pro
whatsapp - fully restored!!!! Hurrah!!!!
most other apps are restored without settings
I have two questions:
1. is there a way to prevent all apps from restoring themselves? this would have been a good way to clean up
2. is there a way to save all settings in the cloud, so apps come back as they were before? I am seriously disappointed in MyBackUp Pro which also only restores mostlly the apk's and ignores the specific changed settings
regards
D.
regards
D.
1. You can't, unless you disable "backup with google" ! BUT, the apps won't start downloading the moment you enter your google account, so you can STOP them from market. AFAIK, only after you ACCEPT the terms and conditions from Play store [after factory reset] only then the apps download themself !
2. NO and NO ! This is the dev's fault [I ALSO HATE THIS !!!] !
...Y U NO PUT SAVE ON SD Mr. Developer ???
You can do what you are saying there >ONLY< if you are rooted using TitaniumBackup !
