Factory Data Reset & Re-Root Help
To start, I have a Droid R2-D2 running the most recent update (2.3.3)
Before I had any problems with the device, I rooted my phone w/ z4root (assuming this helps at all).
When I received a notice that there was an update available for my OS, I updated my phone and almost immediatly started experiencing problems, such as lag and what-not. Afterwards (without doing any research) I performed a factory data reset on my device, thinking that it would also un-root my phone.
Now I'm stuck trying to figure out how to re-root a device that thinks it's still rooted (which it technically is), but I can't use other programs that I used to use, such a Milestone Overclock.
I re-installed z4root and attempted to re-root the device, but while it was in the middle of whatever it was doing, the program force quit and would not open again unless I performed another factory data reset.
Seeing as how I only have a Macintosh computer at my disposal, is there any way that I can re-root the phone so I can use these applications I used to without "bricking" my phone?
