Help FACTORY MODE ERROR
Hello guys my son has a android Galaxy S3 and he's getting a message saying that Factory Mode
DO NOT TURN OFF TARGET well my son removed the battery and put it back in, this works but I really recommend doing it once then go to a mobile network provider like Version and get a new battery. Once you have a new battery find a auto backup app and a secret app for better safety that your phone is safe.
https://www.google.com/imgres?imgur...8vMAhWDKsAKHWd6B-0QMwgdKAEwAQ&iact=mrc&uact=8
Hi
There is no harm in removing and re inserting the battery to get out of "download mode" which is what your screenshot shows. I don't think the issue has anything to do with a faulty battery.
If the phone randomly goes into this mode (ie not on purpose - that requires booting while holding home and vol down buttons when pressing power button) then it has probably suffered from a bad software update. In that case it needs to have the software reinstalled. You can do this yourself using Odin and download mode plus a PC , but if you have no idea what I'm talking about it may be best to let your provider do it. (_there are how to instructions available on the web if you want to give it a go)
Back up everything before this process because it will wipe the phone whoever does it.
