Help Factory reset Behold 2
Erick
After installing the Behold II OTA 1.6 Tweaked i went to the market and tried to install something, it said "no memory to install this app"..
Someone here told me to Factory Reset my phone and this is what i did.
I did the factory reset but it still shows it has 0 memory in the phone. :/
What i did..
1.turned off phone.
2.took of SIM card.
3. pressed down vol. key then send key then end key (not at same time)
4.(phone got to recovery mode)
5.Pressed Menu.
Now it's on but it still shows on the memory status that it has 0.
Maximum: 0
Available: 0
Did i do something wrong?
What i did..
1.turned off phone.
2.took of SIM card.
5.Pressed Menu.
Maximum: 0
Available: 0
You're making it way too complicated.
1. Boot phone normally
2. Open your app drawer
3. Select the 'Settings' Icon
4. Scroll down to 'Reset settings' and select it
5. Select 'Master reset' (This will restore factory values)
