# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=MID
ro.build.display.id=V0.06.MID.eng.ricky.20110808.115238
ro.build.display.id.b09ref=PR70_A_BN_W_R_X_08082011
ro.build.version.incremental=eng.ricky.20110808.115238
ro.build.version.sdk=8
ro.build.version.codename=REL
ro.build.version.release=2.2.1
ro.build.date=Mon Aug 8 11:53:32 HKT 2011
ro.build.date.utc=1312775612
ro.build.type=user
ro.build.user=ricky
ro.build.host=ubuntu
ro.build.tags=test-keys
ro.product.model=10A01.A
ro.product.brand=generic
ro.product.name=a03ref
ro.product.device=a03ref
ro.product.board=m1ref
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=Amlogic
ro.product.locale.language=zh
ro.product.locale.region=CN
ro.wifi.channels=
ro.board.platform=
# ro.build.product is obsolete; use ro.product.device
ro.build.product=a03ref
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=V0.06-user 2.2.1 MID eng.ricky.20110808.115238 test-keys
ro.build.fingerprint=generic/a03ref/a03ref/m1ref:2.2.1/MID/eng.ricky.20110808.115238:user/test-keys
# end build properties
# system.prop for Amlogic M1 reference board
# This overrides settings in the products/generic/system.prop file
#rild.libpath=/system/lib/libreference-ril.so
#rild.libargs=-d /dev/ttyS0
ro.sf.lcd_density=160
keyguard.no_require_sim=1
wifi.interface=ra0
#camera.name is the name define in kernel
camera.name=camera_gc0308
#camera.resolution is the default resolution
camera.resolution=640x480
#camera.mirrorfilp is depend on the camera position
camera.mirrorflip=0
# Time between scans in seconds. Keep it high to minimize battery drain.
# This only affects the case in which there are remembered access points,
# but none are in range.
wifi.supplicant_scan_interval = 60
#alsa.mixer.playback.master=DAC2 Analog
#alsa.mixer.capture.master=Analog
dalvik.vm.heapsize=32m
# Disable un-supported Android feature
hw.nopm=false
hw.nobattery=false
hw.novibrate=true
ro.sf.hwrotation=270
#0~7 You are required to get the correct install direction according the sensor placement on target board
ro.sf.gsensorposition=7
# Use OSD2 mouse patch
ro.ui.cursor=osd2
#for multi-camera support
ro.camera.id.max=0
persist.sys.camera.default=0
ro.camera.gps.rocation=0
#Enable Amlogic player buildin
media.amsuperplayer.enable=true
media.amplayer.enable-acodecs=asf,wav
media.amplayer.enable=true
media.amplayer.support-exname="divx,h264,avi,ts,m2ts,mkv,mp4,mpg,mpeg,rm,rmvb,wmv,ts,dat,vob,vc1"
media.amplayer.support-exname1="mp2,mp3,ac3"
media.amsuperplayer.m4aplayer=STAGEFRIGHT_PLAYER
media.amsuperplayer.defplayer=PV_PLAYER
# ADDITIONAL_BUILD_PROPERTIES
ro.config.notification_sound=OnTheHunt.ogg
ro.config.alarm_alert=Alarm_Classic.ogg
media.stagefright.enable-player=true
media.stagefright.enable-meta=true
media.stagefright.enable-scan=true
media.stagefright.enable-http=true
ro.opengles.version=131072
hw.nophone=false
ro.board.gps.module=AR1520
ro.kernel.android.gps=ttya
ro.board.tscalibration=tslib
net.bt.name=Android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
thanks for your attention.
sir, this is build.prop file i found it with "root explorer app" anyway,
wifi is not turning on , while turning on it gives com.android.settings not responding error and "Unable to scan for networks" error at the bottom. Now what should i do?
