Help factory reset firmware reset?
ash_91
Hi, sorry if this has already been asked I have been googleing!
If i do a factory reset will the firmware be reset to the one that came with the phone?
If not does anyone know how to downgrade to an earlier version as I want to root but have unfortunately upgraded to the 3.13 firmware :(
I have seen this guide but I dont fully understand where I put the files? [GUIDE] Downgrade from 3.13 (Sense 3.0) roms - xda-developers
Cheers Ash.
Hi
As far as I understand factory reset just takes your phone back to basic settings etc but any firmware updates remain as is ....hence the only way to uninstall one is via rooting? XDA presumes a certain amount of tech knowledge so to help out this forum have created the DHD ' all things root' section which explains it in layman's terms. Have a look there and it should help?
Hi
Yes - Factory reset wipes data, etc - it put's the phone back to an "out of the factory", as in completely blank, but it will not affect the firmware.
You could either root or there are .ruu files - these are ROM Update Utilities (or something like that) - these are like .exe files that run from your PC and can restore your phone to stock (meaning that, should you have rooted your phone, it can be reverted back to how it would have been when it came out of the factory, with Stock ROM, Radio, Kernel and Recovery Image)!
The factory reset option within the phone will just wipe everything and take you back to its original state...if you're on a custom rom..it will take you back to the bare custom rom state without the customization or data that you may have subsequently added after flashing it....if you want to restore it to Samsung stock...you WILL have to flash a stock rom...and will lose root then...hope that helps
As far as I'm aware, the advanced ace hack kit now works with sense 3.0 roms, it will downgrade/root etc with one command, however it will wipe everything from your internal memory.
Check the XDA thread or the root sticky round up in this forum for info
Edit: just checked and it only works with certain builds, I can't give you a link as i'm on my phone :( It's on the first post of the xda thread
