Help Factory Reset for Potential Water Damage?
Dlegale90
I was camping this weekend, and on Saturday the tent leaked. My phone (Samsung Galaxy Stellar) got soaked. The phone would turn on, and the only difference I could see was a decrease in battery. I pulled off the back, and removed the battery and SIM card. Water poured out, and so I put it in a bag to dry off when we got home. After getting home I put in rice (As per the internet's suggestion) and a few hours later, the phone would not function properly. The screen will light up, say "Samsung", and then show a picture of the Android bot with yellow lines spinning through his body. I am then taken to a screen where it says:
"Android System Recovery <3e>
Volume up/down to move highlight: power button to select.
reboot system now
apply update from ADB
apply update from external storage
wipe data/factory reset
wipe cache partition
apply update from cache
(Here it shows a picture of the Android bot with his chest panel opened, and a Red "Caution" triangle above him).
# Manual Mode #
--Appling Multi-CSC...
Applied the CSC-code: VZW
Successfully applied multi-CSC."
If I select the first option, to reboot the phone, I am taken back to this screen. None of the other options will do anything, and I have tried to do all except for Factory Reset. When I press this, I am given several options of "No" and one "Yes-Warning, this cannot be undone!".
I am hesitant to press this button, as I don't want to factory reset the phone. However, it is preferable to the alternative of trying to get a new phone. Would factory resetting the phone fix the damage done? If not, will leaving it in the rice for a few more days work?
reboot system now
# Manual Mode #
Water damage is tricky as all bull to deal with sometimes rice works sometimes it doesn't sometimes the phone is fine sometimes the phone dies, sometimes the phones works alright......for. while then dies due to corrosion
