So I bought a used Galaxy S3, and would like to do a factory reset. I looked it up and there are 3 ways to do it. Is there any difference to those 3 methods, maybe one way is better than the others?
If you aren't rooted, all the methods are the same. If you are rooted, though, doing the reset from a custom recovery allows you to reset the phone without wiping the internal memory.
