factory reset troubles
ktbiggen
I did a factory reset on my phone today, and the apps that were saved on my sd card arent showing up. I took the sd card out before the reset and mounted it when i put it back in and still nothing. Any help?
Apps dont save to your sd card unless you were rooted and used Titanium Backup to back them up. If you arent rooted, the only thing that is saved on the sd card is apps data, like game saves for example. You will still have to reinstall any apps you had before.
