D DeeGod Guest Dec 23, 2016 #1 How to factory reset when phone has numeric security lock and I can't remember it
Sudhanshu kumar Well-Known Member Dec 23, 2016 #2 Hey there Welcome to AF Let us know the device your using? model? You need to factory reset it using the Recovery (custom or stock), for that you need to press some combination of keys while its switched off . Thanks
P Parayilhussain Android Enthusiast Dec 23, 2016 #3 Hi, Open the link below Select second option https://support.google.com/android-one/answer/6088915
