Help Factory Reset
jradicle11
That Guy
Is there any way to factory reset without going to settings > etc.
I tried to original Droid method but press the camera and volume up buttons didn't work.
Alright I got to the screen with the little triangle and the android guy and began pressing random buttons on my phone and was able to get the Android system recovery menu to pop up.
What is the difference between "wipe data/factory reset" and "wipe cache partition." I know factory reset will delete everything but I'd like to avoid that if I can. Mainly because I don't think my FF7 saved game is on my SD card...
Runs perfectly, haven't had an issue yet. I guess it was saved to my SD card because I still have my saved data after a factory reset.
