Factory Resets for Cricket Androids
amyatomic
If you know the factory reset for any other cricket androids that I may have missed, please add them!!​
Please Notethat if you reset your device to the factory defaults all of your data including contacts, messages, etc. will be lost! Remove your memory card to preserve anything saved on it, and remember to remove the SIM card if your phone has one!​
Samsung Galaxy S III (SCH-R530C)
  • Power off the phone
  • Press Volume Up + Home + Power simultaneously
  • Use volume down to select wipe data/factory reset
  • Select with the power button
Samsung Vitality (R720)
  • Press Volume Down + Back + Power simultaneously
  • Select with the home or power button
Samsung Transfix (R730)
  • (with keyboard open) Press Volume Down + the letter R + Power simultaneously
  • Select with the home button
Samsung Indulge (R910)
  • (with keyboard open) Press the letter R + Power simultaneously
  • Release both buttons when the Samsung screen appears
LG Optimus (LW690)
  • Press Home + Volume Down + Power simultaneously
  • Select with the menu button
Kyocera Zio (M6000) (option 1)
  • If the phone is locked from too many pattern attempts or forgotten Gmail account, go into the Emergency Dialer
  • Dial ##4357*
  • Scroll down and select Reset
  • Enter 000000
Kyocera Zio (M6000) (option 2)
  • Press Volume Down + Camera + Power simultaneously
Kyocera Hydro (C5170)
  • Press Volume Down + Home + Power
ZTE Score (X500)
  • Press Menu to show Android Recovery System
  • Select with the camera button
ZTE Engage (V8000)
  • Press Volume Up + Power simultaneously
  • Release when the triangle/exclamation point screen appears
  • Press Volume Up + Volume Down simultaneously
ZTE Groove (X501)
  • Power off the device
Huawei Ascend I (M860)
  • Press Volume Up + Call + Power simultaneously
  • Select with the track ball
Huawei Ascend II (M865)
HTC Desire C (H1000C)
  • Press Volume Down + Power
  • When asked to confirm, press volume up
HTC One V (H2000C)
HTC One SV (H3000C)
Alcatel Authority (ADR3010C)
  • Select with the search button
Factory reset shouldn't erase anything on the external SD card. Also, I've never heard of having to remove the SIM card, but I'm not positive on that.
I always take the sd card out of the phone just as a precaution, I know it's more than likely unnecessary. However, with the SIM cards, I'm completely unsure of the effect on leaving it in the phone during the reset. I've read some places that it should be removed but most places don't mention anything about it! I've never reset one myself, so I guess I'll find out when the situation happens! :p
