Help Fail in send message
Wise11
Hi
I have problem I sent one mail to many emails in bcc but gets me error message although all emails are correct
This message
Invalid Address
One or more email addresses do not
appear to be valid. Please correct it
before sending email.
See attached
Depending on the email app/program you used, the rest of the emails went on their merry way.
but one of them did not.
I usually get an error message back with the bad address listed, then I go and look to see what I did wrong.
some apps, can be overloaded with too many recipients in the BCC address line.
You will need to verify that each and every email address is valid.
and you will need to verify that when you put their addresses in the BCC line that no "extra spaces" or other characters got added to the mix. that will produce errors like you posted.
My email is gmail and no accepting in bcc I do not why tell me correct ways to sending successfully
I understand the difficulty with translating languages, but.........
"Gmail" is your email service provider and that is Google Corporation.
And the default email app on your phone is also named "Gmail", but they are NOT the same thing.
The first is a Service that allows you to send and receive emails. There is NO requirement that you use the phone's Gmail app to do that.
Your problem as stated was that when you sent multiple emails on the BCC line, that you got an error message.
That just means that one ( or more ) has an invalid address.
That address may be bad now,
or you may have typed in extra characters that corrupted that email address​
It don't matter how it happened, you must verify each email address as good, by sending just one email to that person. If you get a reply back, that address is good.
If you are able to send everyone email, and you get replies back from all of them, then you have proven my first point.
You typed in an extra character somewhere and that corrupted that one ( or more ) email addresses.
