Design-wise, the stock dialer is fine... except that when I tap on a name to call, it takes a second or two before the "Call Using" dialogue box pops up to let me select which SIM to make the call.
The lag might not sound significant but it is annoying if you're juggling calls in a customer support capacity.
It would help if the dialer remembers which SIM I used the last time to call the contact, OR simply use the SIM where the call initially came in for future outgoing calls to that contact.
Yes, I've tried out the usual suspects (exDialer, Truedialer, etc.) but they all seem to be using the factory dialer underneath the skin, as they also present me with the same "Call Using" dialogue box and the accompanying lag.
Any ideas are welcome.
Thanks!
Thanks!
I don't know what happened but I tried it again and the pop-up no longer comes out. I restarted the phone to be sure it won't return to the default dialer and it's really gone.
