Hello,
I bought new Xperia Z5, but it had bad battery (discharging 10% per hour and the phone shuts off in 22%) , so I sent it to reclamation, but then the battery it was still bad (phone drain 2-3 % battery even if display off and if I watching Youtube, battery draining 5-10% per 10 minutes) .
So, I tried bought bigger battery (3100 mAh) from German company Polar Cell. After battery changed, CPU-Z app still show 2900 mAh and the phone still draining battery (1-2 % per hour) on display off and 4% on watching Youtube per 10 minutes :-/ .
I tried disable battery optimization, but I don't see any change (only the phone charging longer time) . What should I try next? Factory reset or reinstall system via Xperia Companion? Or this issue is in phone itself?
And yes, I have wifi, NFC and GPS off.
I know, that this phone is little bit hot (because Snapdragon 810) , but in idle or browsing the web is OK. But still, the battery draining too fast. I had Xperia Z3 Compact before and I can use this phone almost three days! Z5 barely 8-9 hours.
Thank you in advance.
