netnerdvana
Battery fast charge seems to be affected by the USB cable length. See attached screen shot from Battery Monitor Widget Pro.
Plugged in the Nexus 7 when it was down at 40% (first vertical bar) using the shorty 3' cable that came with the tablet and a 6' USB extension cable (high speed USB 2.0 Cable by MediaBridge). The outer insulation is fairly thick 3/16". Not sure about the inner wire gauge.
I let it charge for almost an hour and it got up to 58% (just before the second vertical bar) and BMWP reported about a 800mA charge during that time. Then I took off the extension cable at had it just plugged into the same nexus 7 charger with only the stock short cable. I let it charge up all the way.
The charge appears to go much faster like around 1300mA. Also the % available curve steepens until the battery goes into absorb phase at around 90%.
Any suggestions? Are USB3.0 extension cables spec'd to have bigger wire? Do they prevent this effect on Nexus7 fast charge?
