Help Fastboot issue
Stan1k
Hi there,
So I have been working on unlocking bootloader of my device Huwaei Honor 7 [PLK - LO1] ((OFICIALLY)) by obtaining the code from the official website and using ADB.
So, first I got all the things I needed to and did eveything alright and soon after I finished the process my device's screen also showed "PHONE Unlocked".
But then when I restarted my phone it was all back to normal as it was before unlocking the bootloader I'M SAYING THIS BECAUSE I WAS TOLD THAT IT WOULD WIPE MY DATA BUT IT DID'NT, all my apps were at their postion, everything stayed the same.
So I again tried to unlock it then the command prompt said "FAILED (remote: already fastboot unlocked)"
Then to confirm it I used the *#*#7378423#*#* number on my dail pad but it disappears whenever I enter the last digit which is "*", I don't know what is up with my phone.
My doubt is did I unlocked the bootloader already or am I stuck at something mysterious, never happened to anyone before?
If it says the bootloader is unlocked well then it's unlocked. Some devices will do a data wipe and others won't.
