Help Faulty camera??
Hi for some reason my when starting up the camera on my S6 it makes a fuzzy type noise, This also happens on Snapchat, It takes a picture fine no problems its just the noise that concerns me, Should I send it back to Samsung uk?
The only noise the camera should make is a soft rattle if the phone is shook. This should only be heard when shook next to your ear. It is the OIS (Optical Image Stabilisation) hardware. It is actually one of the tests - shake your S6 or S6 edge, then as quick as possible take a photo of something in auto mode. It should be crisp and clear.
I'd take yours back, but before you do , and I know it is a stupid question you have taken off the camera protection film from the lens haven't you?
