Help Faulty Glass
Hi all,
I recently had the glass on my s3 repaired and it hasn't been done very well. I can practicaly lift it straight off the screen! The shop I took it to is denying any knowledge of it. Is there anything I can do myself to secure it to the screen?
Hi all,
Hi, i don't see how the repair shop can deny any knowledge of it, they did the repair and it should be of satisfactory quality, unfortunately you do not have your location in your profile, this always makes it more difficult to give specific advice, but if you are in the UK I suggest you contact Trading Standards. Phil
