Root F'ed my Esteem - Please help.
Dubstep
I deleted Superuser.apk with Root Explorer, then my phone randomly turned off.
Now whenever I boot my phone up it boots into CWM.
In CWM I try to flash GingerSteem Extreme ROM but when the phone reboots, it boots into CWM.
I'm screwed? :eek:
I'm screwed? :eek:
Sounds like you need to flash something with superuser already installed. Just curious? Why would you delete that APK?
I'm screwed? :eek:
not sure if it helps but did you try the recoveryloop fixer thing? lol or just flash a rom with su..
+1.. The link is in all things root guide.. Look for clockworkmod bootloop fix and flash that.. Should be able to flash gse after that.. Many people have had that issue..
I can't mount my SD card to my computer.
I'm using an SD card reader and downloading the Stock ROM.
Wish me luck.
hmm you never had made a backup? a backup should have SU because it backs up everything right?
