Root femine roms??
Kg198202
Are there any roms that are very girly/femine? Preferrably black and pink with most features working?😍
If I remember correctly, ziggy46 was working on a feminine themed rom like that at one time. I don't remember if he released that or not.
EDIT:You could probably just install cm7 or miui and download a feminine theme. I'd recommend CM7 G60 Style. Then go to the theme Chooser app and install a girly theme.
You could probably just install one of minimal roms and tweak the colors to look girly lol.
Thanks! Im new to installing roms, this will be my first time so i dont know where to begin to tweak it...
If you want to get a feminine theme for your phone but don't want to risk bricking your phone or whatever you could just download a different launcher from the android market (i.e. go launcher, ADW launcher, etc) and get a theme for that.
I also saw a couple feminine themed roms on here too. This is also where you can learn to install ClockworkMod Recovery and alot of other stuff. It's really not that hard to do and doesn't take much time. Just read through it carefully.
http://androidforums.com/triumph-al...l-things-root-guide-updated-04-22-2012-a.html
I have the CWM installed and I believe the nandroid backup..I just have to figure out what rom to go with.
I have the phone rooted and the CWM already installed on the phone, as long as i can go back to stock easily Im cool:cool:
Im currently using Go launcher etc...just wanted to try to something new and hopefully increase performance
Thanks for your response.
