Hi,
I'm new to these forums, and just got an Aria on Tuesday. It's my first smartphone, so I'm still figuring out a lot of it. I have a few questions regarding the Wifi though...sorry if they're fairly obvious to answer, like I said, I'm new to this.
So I'm assuming you can either use Wifi or 3G? Does this mean that when you are in a Wifi area that you can connect to (for example, my home), that when I'm in this area my phone does everything via Wifi (downloading apps, emails, facebook, etc). But when I leave my home and go elsewhere, out of the Wifi range, it switches over to 3G?
Does using Wifi use any of the data usage of your phone? Or is that only when you use 3G?
I also had one other question - How low can/should you let your battery get before recharging? I've had it before that if I recharged too early the battery stopped lasting as long. Just curious how low everyone lets their phone get?
Thanks in advance!!
Thanks in advance!!
