hey im new to the forum but ive been browsing the site for a while... I have some questions (hopefully not repeats) about the Connect...
1. This one is about the battery: Should i let the battery die down to 0% or should I charge it before... (stock battery)
2. Does anyone know if there is background data widget/toggle? Is the an app that will do this with one touch? Im currently using "Sync Settings" to have a shortcut...
3. General Q: Does wifi disturb the strength of the cell signal?
-Most of my neighbors have wifi, so i think that is why i do not get a strong signal inside my room.
4. When ever i power on my phone, the time is not correct. anyone else have a similar problem? it automatically retrieves the right time when i turn on the signal...
---*** 5. Is there a way to change how many time the phone vibrates for text notifications??
6. do radio apps use data??/ I used it on WIFI but it didn't show on my data/wifi tracker? I used ESPN Deportes Radio
hopefully someone can help me out.... thank you!
