dfine06
Ok so i have root finally but i have a bunch of problems it seems and i really need some help.
1st:
I have smoked glass 4.0 installed and it seems to be super buggy and forces close on me many times in the day. I want to installl 4.5 but it wasnt working for me last night.
My question is should i reboot from my stock nandroid backup.
-Delete the old file.
-install the new smoked glass?
-is it less buggy?
-i love the 2.1 one look is there another ROM that has that?
2nd:
-Im overclocked and my setcpu say 950 but it seems to be running pretty slow and the temp isnt hot which makes me belive it may not be running at that?
-Does it have to do with the theme?
-How can i tell if im truly overclocked?
Thanks!!!!!
1st:
-is it less buggy?
2nd:
Thanks!!!!!
