Few steps forward, few steps back.
rushmore
Extreme Android User
Good:
Even nicer keyboard
Same zippy upgrade in chip and ram as Razr
Webtop (if you use it)
Bad:
No replaceable battery (extended option is good on D3)
Need a key to swap sd cards
FM radio function gone
Apparently same display as D3 (Razr display tech is better). A smaller version of the Razr display would have been nice.
Several GB internal storage gone due to Webtop
Seems that of all the recent device refreshes, most Droid 3 folks should be the least upset.
I have a 64GB card, so no biggie, but having the same apparent display as the D3 is an issue for me. They should have went with the Razr display tech. Much better.
I hope this info is incorrect, since the D3 display has ghosting with certain colors.
I was nosing through this forum as I'm interested in this phone. I have the Razr Maxx but sometimes miss my old slide out keyboard.
I had a heck of a time opening the door to put the sim card in too. I ended up using my CVS keychain card, you know, the small one you put on your key ring. I didn't notice any special tool to open that door in the packaging.
It's in a little pink bag, a little bit smaller than a guitar pick.
