File Expert is a small fast and powerful file manager for Android platform. Supports all file operations. It can share your cell phone files using FTP/HTTP via WIFI. It means you can access your mobile phone on your computer without any cable. File Expert also can access your computer which is running SMB file sharing service.
Features:
* Powerful & Leading File Manager
* FTP/HTTP sharing-Share your files without USB cable
* SMB Client-Access your host computer
* App Manager-Uninstall/Backup apps.Silent install APK supported
* Zip/Unzip
You can download for free and leave the comments here.
If you really think that FE could change the way you sharing or managing files,please make a donation to us, Thank you.
We will appreciate very much if you leave comments here.
File Expert-Your best Android file manager and sharing app!
V3.0.2 Change Log
1. Fix toolbar transparent bug, it is now works as expected and will not activate below items.
2. Fix simple list bug.
3. Show full path on search results.
4. Allows users to perform operations on search results.
V3.0.0 Change Log
1. New UI, New User Experiences, tell us what you think about our new UI and experiences
2. Fast Back support
3. Fully customizable toolbar, please try it and tell us your comments about this feature
4. Many many enhancements and new features, feel free to explorer it and enjoy new File Expert!
Main Features:
* Powerful & Leading File Manager for Android - We have thousands of new users each day!
* All basic file operations - Copy, Paste, Move, Create and Rename your files and folders
* FTP/HTTP Server - Share & Manage your files without a USB cable, just like with Web Sharing or WIFI File Explorer, but we do even more because we can provide both Web & FTP transferring support. We support HTTP authentication and FTP account login.
* SMB Client - Access your host computer from your phone, using your phone to manage your PC via WIFI with SMB
* App Manager - Uninstall/Backup apps. We know that many apps on the market can do this, but none can do this work silently. We're the ONLY app that can install and uninstall apps silently, which makes your batch process faster and cooler. Silent capabilities require a rooted phone to function.
* Zip/Unzip - Create and decompress ZIP archive. You can view your ZIP file just like accessing a folder
* Thumbnails - supports jpg/png/mp3/mp4/3gp thumbnails
* Text Viewer - supports very large TXT files. This feature is still under development, we will continue to improve its functions
* Image Viewer - supports both local and remote folder, we will support gesture detection and multi-touch zooming in the future release
* Search SD card
* Help your player to play media that stores on SMB share (your player needs to support HTTP streaming). Just like some users on the app comments said, WE are the ONLY file manager that can directly open some types of videos over SMB network
* File Picker - Let FE to help you anywhere you want
Why choose FE? Here are the reasons:
1. No ADs and it's FREE
2. Gives you almost everything you need to manage your phone's resources
3. Smaller size than competitors (Astro and ES are all bigger than 1MB, but FE is only 851KB)
4. Acceptable performance
5. Free technical support via email
6. Clear User Interface, and most operations can be done only in touch
7. The ONLY file manager that supports both PC 2 phone & phone 2 PC wifi file transfer and can directly play some videos and music via SMB
Give it a try and you will find more useful features!!!
We know that Astro is great but you have to buy Pro version in order to remove annoying ADs. We can provide all functions that Astro does and offer you even more useful features like Web sharing support. Why not give us a try?
We released a new update please have a try:
We cancelled the grid view because a lot of people will not use it usually.
We will think of letting it back if people want that.
File Expert V3.0.4 Released, ROOT added
V3.0.4 Change Log
1.Improve toolbar performance
2. Add root operation support (BETA), please use it very carefully. If you need this function please enable it on settings first.
3. Fix some bugs.
4. Add support for creating folder shortcuts on desktop 5. Add Hebrew, Russian language support
FE has been made three updates within one month. First it got update with totally new UI, then this time Root function as added. Thanks to the DEVs, we can enjoy a more powerful file manager with more useful functions.
Hope it will became more stronger.
Main Features:
* Search SD card
Screenshots& apk file: see the attachments
File Expert is a leading file manager in Android Platform. You can share your files with another device via WIFI connection.
Features:
* Search SD card
* Root support: mange your system file on a rooted phone
* Unrar: decompress ZIP archive
* Theme Customization: you can choose your favorite skin. More skins will come soon!
And it's totally free and no ads!
Email: support@xageek.com
Features:
* Zip/Unzip
V3.0.2 Change Log
V3.0.0 Change Log
Main Features:
* Search SD card
i hate it. the new bar is too transparent and its easy to hit a folder instead of an operation. the grid view i seem to not be able to find. i just downgraded until its tweaked some more.
V3.0.4 Change Log
3. Fix some bugs.
Main Features:
* Search SD card
Features:
* Search SD card
