Help file issue Galaxy replacement
wilkesd
I have a replacement Galaxy S3 and I moved some gaming files over to my PC before I got the phone replaced a and have them back on the phone but I can't access the game for my son. It's Mine craft for a 9 yr old. How do I get them back to a playable mode?
It depends on what you saved. If it's the apk file of the game, put it on the new phone and press it - it'll install the game. If not, go to the Play store and install it again.
Hello and welcome to the forums . I see your having trouble with a game app data you saved . now was the device rooted . if not that's the only way you can force app data . You can do is when the app you download makes a folder . open the folder and remove the files and copy and paste your app data in its spot . now if your rooted you can set the permission to the files and began where you left off .
