File Management
lio52
Hi, hope someone can please help. In order to free up some phone memory, is it possible to move apps/apps folder onto the sd card without affecting their function? I have android 2.3 installed.
Thanks
Alex
Don't be surprised if you wouldn't be able to move all apps. Some of them are not programmed to be moved. Also do not move the apps if you want to use their widgets.
