file system
  • Start date Start date
A
Android Question
Guest
how can i access the file system of other android devise ti find a particular file from the devise using wi-fi?
If the other device is running WiFi File Explorer and you are on the same WiFi network then you should be able to browse part of the filesystem using a web browser. I've only done this from computer to android, but can't see why it wouldn't work.
You can't do it without the other device running something like that though. Would be a huge security hole if you could.
