Foxcitiesjd
I need to be able to open a file upload menu from AndroidAddMember.aspx page in a web view. I found this fix but I dont think im implementing it correctly.
m0s' programming adventure: File upload in through WebView on Android
The file upload button works fine in a browser on phone and pc but once in a web view the button does not work.
I embed the page with the button in my first case statement below.
Do i need to set the web view differently in that case statement to get the code above it to work? I wrapped the new code in these brackets //+++++++++++++++++++++
Any help would be great. Thanks
//+++++++++++ New Code to fix the button issue+++++++++++++++
WebView wv;
private ValueCallback<Uri> mUploadMessage;
private final static int FILECHOOSER_RESULTCODE=1;
@Override
protected void onActivityResult(int requestCode, int resultCode,
Intent intent) {
if(requestCode==FILECHOOSER_RESULTCODE)
if (null == mUploadMessage) return;
Uri result = intent == null || resultCode != RESULT_OK ? null
: intent.getData();
mUploadMessage.onReceiveValue(result);
mUploadMessage = null;
public void onCreate1(Bundle savedInstanceState) {
wv = new WebView(this);
wv.setWebViewClient(new WebViewClient());
wv.setWebChromeClient(new WebChromeClient()
//The undocumented magic method override
//Eclipse will swear at you if you try to put @Override here
public void openFileChooser(ValueCallback<Uri> uploadMsg) {
mUploadMessage = uploadMsg;
Intent i = new Intent(Intent.ACTION_GET_CONTENT);
i.addCategory(Intent.CATEGORY_OPENABLE);
i.setType("image/*");
MyGreatActivity.this.startActivityForResult(Intent.createChooser(i,"File Chooser"), FILECHOOSER_RESULTCODE);
setContentView(wv);
//++++++++++++++ End of new code to fix the button issue +++++++++++++++++++++
@Override
public boolean onOptionsItemSelected(MenuItem item) {
// Handle item selection
switch (item.getItemId()) {
case R.id.register:
mWebView2 = (WebView) findViewById(R.id.webview);
mWebView2.getSettings().setJavaScriptEnabled(true);
mWebView2.loadUrl("http://www.Mysite.com/AndroidAddMember.aspx");
mWebView2.setWebViewClient(new HelloWebViewClient());
return true;
case R.id.ratewomen:
mWebView3 = (WebView) findViewById(R.id.webview);
mWebView3.getSettings().setJavaScriptEnabled(true);
mWebView3.loadUrl("http://mysite.com/gadgets.aspx");
mWebView3.setWebViewClient(new HelloWebViewClient());
return true;
case R.id.ratemen:
mWebView4 = (WebView) findViewById(R.id.webview);
mWebView4.getSettings().setJavaScriptEnabled(true);
mWebView4.loadUrl("http://mysite.com/gadgetsmall.aspx");
mWebView4.setWebViewClient(new HelloWebViewClient());
return true;
default:
return super.onOptionsItemSelected(item);
WebView wv;
@Override
Intent intent) {
: intent.getData();
setContentView(wv);
@Override
case R.id.register:
return true;
return true;
case R.id.ratemen:
return true;
default:
