Help Finding and Installing Android 2.2
wrebbitt
Can anyone provide me a link or hook me up with the update file for Android 2.2 OS? I've searched and have not been able to find it... and Google doesn't seem to make it available.
Gingerbread is glitchy on my phone and rooting it has not resolved the issues mentioned in another thread (http://androidforums.com/nexus-support-troubleshooting/307974-problems-w-gingerbread.html), so I would like to revert back to Froyo 2.2 to see if that fixes everything as I'm fairly confident, I didn't have these issues while running 2.2
Below are the details of my phone and what I'm currently running, so hopefully installing 2.2 will be compatible with this or I can wipe the phone, install 2.2 then flash cynogen 7 again.
I just really need to find the Androis 2.2 OS file.
I appreciate the help.
Thank you in advance
Root details:
Amon_Ra's Recovery: recovery-RA-passion-v2.2.
1-CM
Flashing Radio: passion.5.08.00.04
Flashing CyanogenMod: gapps-gb-20110307-signed
About Phone:
Phone: Nexus One
Carrier: Mobilicity
Android: 2.3.3
Baseband: 32.41.00.32U_5.08.00.04
Build: GRI40
Download link Android 2.2 FrozenYoghurt :D :
http://bit.ly/aCDBwh
Rename the file passimg.zip and copy it to your microSD (make sure its in the root of your SD card) card via USB. [Note: make sure the file is named passimg.zip and not passimg.zip.zip.]
Power down your Nexus One
Hold down the "Volume Down" button as you power the phone back on.
A screen should appear showing your phone
