finding and setting custom wallpapers
SUroot
Extreme Android User
Here is my little tip for you.
We all know Zedge by now, but one of it's drawbacks is not being able to search easily by resolution. You have to use best guesses of filesize (1MB+)
Here is my tip,
Do a google advanced image search, setting the resolution to 1280 Height by 1440 Width.
Then, download QuickPic from google play. QuickPic will work as a replacement gallery. You can long press > Wallpaper > Quickpic too.
The benefit of using quickpic is that with the Samsung Gallery, you have to crop your own images down to 1280x720, giving you crappy borders as you scroll in your launcher of choice. Quickpic will allow you to use the resolution needed for scrolling.
