startac4
My battery charge % is continuing to drop more than seems to be right for what I'm "normally" doing on the phone. I expect its because there are programs running continuously in the background that are eating up the battery.
How do I (1) identify these programs and (2) how do I stop them? I know that Avast is running and I'm OK with its active security (just as I have it doing on my computer). How do I find the others?
When I go to Settings -> Storage -> -> Apps I see a list of programs that apparently are running. But I don't know if that's true. They may have been loaded when I powered on the phone, but are just sitting there doing nothing at all (except taking up space). I have no use for most of these programs (e.g. Amazon, Lookout, T-Mobile TV, Google Play Movies, Facebook et al). I don't know if stopping any of them would make a difference. And I don't know a safe way to stop any.
One time I found a place to stop something - I can't remember where that is on the phone - and got this dire warning to the effect that stopping the program can have unpredictable results, which would seriously impact the use of the phone. When I select one and try "clear data" - I don't what that would really do - I get another dire warning that all kinds of things will be lost forever.
The question comes down to how do I find which programs are continuously running (including ones that I don't know about,) how do I stop them without having "dire, catastrophic results", can they be "re-started" if for some unforseen and strange reason I actually wanted one of these programs in the future, and is there a way to stop these and keep them stopped without having to do this every time I power on the phone.
Oh by the way - I just installed Signal Messaging. Can that be one of the culprits? If so, is there a way to stop it without deleting it from the phone? I need that only for a very, very limited use at just occasional specific times.
Update:
I just found a list under Settings -> Battery & Power Saving -> Battery Usage -> Battery Use Details.
It shows Screen as taking 27%, Phone Idle 7%, Android System 4%, Android OS 3% and a bunch of others around 1%-2% (including dex2oat, what's that?). I don't see anything that would explain the precipitous drop from 39% to 26% in about an hour (without any phone calls or text messaging). Nor do I understand the difference between Android System and Android OS. As for Signal, it's not even listed here, though I know I had been looking at it (though not actually using it).
Any suggestions as to what I should do from here? It appears to me that something is significantly draining the battery - and I don't know just what it is nor what to do about it.
Update:
