Eric Parlatore
I don't think the fingerprint works as great as it should
If you haven't already, please try the following. It really improves fingerprint recognition.
Use your favorite finger and create 4 separate fingerprints of the same finger on the phone. Feel free to use different angles and positions.
Once you've done this tap on 'Check added fingerprints' and test your finger at different angles. Make note of the fingerprint numbers that occur more frequently out of the four separate fingerprints you have created on the phone.
Now remove the fingerprints that do not frequently show up during this process and retrain these using the same finger.
Repeat the above process.
You will be surprised how much more accurate your fingerprint reader will become once you have done this.
I use my thumb as my primary 'finger' in all four fingerprints. Using this method I then fine-tuned it to the two best fingerprints. I then added another finger to the other two available fingerprints repeating the same process to find the best combination for that finger.
