LaineKat
So, I read through some posts on here about memory and storage until my brain felt like mush. I'm honestly not technical at all and my IT techie husband is too busy programming and working to help
. I bought a 64GB external SD card for my LG G Stylo (not rooted, don't even know how - tried looking into it and it might as well be a whole other language) last night and started moving apps over. At first they all worked fine (ones that could be moved obviously). Then suddenly I started getting the old "Insufficient storage space" message. Funny thing is, some apps look like they're going through the move process then I get the message at the end, and some tell me right off. When I look in settings, it tells me I have 14.93GB used of 16GB internal space, and 568 MB used of 60.05 GB on my SD card.
Wonky things seem to always happen after I get a system update.
. I feel like system updates will eventually take up all my internal space.
Also, is there anywhere I can set apps to auto install to SD card unless they have to be on internal?
Android Version - 6.0
Photo of Settings - Storage & USB
. I bought a 64GB external SD card for my LG G Stylo (not rooted, don't even know how - tried looking into it and it might as well be a whole other language) last night and started moving apps over. At first they all worked fine (ones that could be moved obviously). Then suddenly I started getting the old "Insufficient storage space" message. Funny thing is, some apps look like they're going through the move process then I get the message at the end, and some tell me right off. When I look in settings, it tells me I have 14.93GB used of 16GB internal space, and 568 MB used of 60.05 GB on my SD card.Wonky things seem to always happen after I get a system update.
. I feel like system updates will eventually take up all my internal space.Also, is there anywhere I can set apps to auto install to SD card unless they have to be on internal?
