How do I downgrade Lg eve to a lower version? I want to follow this guide: Installation | OpenEtna but it says i need to downgrade. Can anyone tell how?
If you are running on a Rogers/LG stock firmware you should be fine, the most recent version is v10f.
From there with OpenEtna it's just installing on the software on your PC and making sure your Eve is in USB debugging mode for Fastboot to work (Settings, Applications, Development).
I was able to do it with Spacebar alone, as soon as I plugged into the USB port on the PC (without the battery in) ... some text appeared when the LG logo did - if you get passed the LG logo, it's too late.
If it's not working, consider putting v10f on the phone, you can get the software from www.lge.com
