Help firmware update help needed
Irishcali
So I have a htc one m7 att unlocked phone. ? Is do I download the firmware for att even tho am using metro? Or do I update using the t-mobile metro firmware?
Htc told me to download the att one. But wouldn't tell me why. I don't care about the att apps. any ideas? thanks
I can't update with the phone. since its not hooked up with att anymore. I have to download the file and use my computer.
Firmware is model specific. Your AT&T version has a different model number than a T-Mobile version. I'm not familiar with HTC devices but that is the way it works with Samsung, Motorola and other devices I've owned.
Good to know. I will make sure I install the att one. htc is in the shop.
need to update s3 but can't find the firmware updates, On att or samsung. I had to do factory reset today so everything is from 2013
