Josh Taylor
Need help with a firmware file for the sunvell t95z plus box amlogic s912 2g 16g. Or a tutorial on how to extract the firmware off the box any help would be great thanks
Or a tutorial on how to extract the firmware off the box...
http://freaktab.com/forum/tv-player...l-s912/firmware-roms-tools-by/606442-firmwareHello, who has this firmware? T95z plus firmware T5ZP0030, my wifi is down, dead, out :'(
Using it to run Kodi & cannot upgrade to 17 unless it's on Android 5 or better. I expect sooner or later the support will stop if or when I have issuesFirst of all... WHY do you want to upgrade the Android version?
Mine runs 4.4 also and I have not yet found a compelling reason to (risk an) upgrade to a higher version.
Fair enough. I'm in the same predicament.
Yeah, I'm looking into new devices also. Picked up a MadCatz Mojo. Love it but it requires modding and it's a little complicated but once done, its fast ! Not sure if I can spend the $$$ on a Nvidia Shield
Not sure if I can spend the $$$ on a Nvidia Shield...
