).And that should take how long?
Keep in mind you never want a battery to go to 0% charge. It could ruin the battery.
Is that true bro? In what way? :beer:
I think android shuts down at 1% (or a certain voltage) anyway so it has enough power to do a clean shut down but ive never heard about fully draining a battery ruining it
4: Avoid completely discharging lithium-ion batteries
If a lithium-ion battery is discharged below 2.5 volts per cell, a safety circuit built into the battery opens and the battery appears to be dead. The original charger will be of no use. Only battery analyzers with the boost function have a chance of recharging the battery.
Source
Thanks man. Id never heard of that :beer: i suppose though, at the same time, an android device will never let the cell fully discharge.
Maybe this is why water damaged batterys sometimes die, like they get shorted and fully discharge?
