Nbgorman
Member
Hello! I am 15 and i have gotten my first car as a gift... The catch is the engine is seized. No problem I say I'll pull it out and rebuild it! So to give some background information, the enging seized and the car is a 1996 Dodge avenger and the particular engine is a DOHC 2.0 L 420A I4 (Same as a neon) and it has the stock manual 5 speed in it, the chasis, transmision, and the engine have roughly 200,000 miles on them. Also I BELIEVE the main crank bearings blew. So I have been saving for the past 6 months and I am at a grand totall of $890 with at least another $150 coming in january. I am asking you guys or help. I plan on beefing the engine up with the transmission being able to support it. I also plan to redo the suspension. Now do you fellas have any advice for parts [Or manufacturers] I would like to get a high preformance cylinders, cylinder head, exhaust manifold, intake manifold, and exhaust systems, (I know I cant afford all )I own the required tools to rebalance the engine and to check compresion as my grandfather built drag racing engines and when he died my father enhareted all of his tools.
