Apps First coding help
My first coding project is a soundboard type thing on andriod using eclipse (on 2.3.3) and im really confused as to whats wrong with my code, I dont get any errors but the button doesnt play the sounds. If anyone could have a quick look at the code that would be great
Code:
package com.mkyong.android;
import android.app.Activity;
import android.content.Context;
import android.content.Intent;
import android.media.MediaPlayer;
import android.os.Bundle;
import android.widget.Button;
import android.view.View;
import android.view.View.OnClickListener;
public class AppActivity extends Activity {
	Button button;
	@Override
	public void onCreate(Bundle savedInstanceState) {
		setContentView(R.layout.main);
		addListenerOnButton();
	public void addListenerOnButton() {
		final Context context = this;
		button = (Button) findViewById(R.id.button1);
		button.setOnClickListener(new OnClickListener() {
			@Override
			public void onClick(View arg0) {
				Intent intent = new Intent(context, App2Activity.class);
                startActivity(intent);
	public class PlayIt extends Activity implements OnClickListener {
    MediaPlayer mp1;
    MediaPlayer mp2;
    public void onCreate1(Bundle savedInstanceState) {
        mp1 = MediaPlayer.create(this, R.raw.froze);
        mp2 = MediaPlayer.create(this, R.raw.lasagna);
        final Button button1 = (Button) findViewById(R.id.button1);
        button1.setOnClickListener((OnClickListener) this);
        final Button button = (Button) findViewById(R.id.button02);
        button.setOnClickListener((OnClickListener) this);
    public void onClick(View v) {
        switch(v.getId()) {
        case R.id.button1:
            mp1.start();
            break;
        case R.id.button02:
            mp2.start();
            break;
    @Override
    protected void onDestroy() {
        mp1.release();
        mp2.release();
        super.onDestroy();
In first class AppActivity you set on button click listener to go to App2Activity, row:
Your another class is activity named PlayIt. You should change upper row to:
Intent intent = new Intent(context, PlayIt.class);
Another thing, Activity PlayIt should report error because you need to put setContenView(R.layout.your_layout) before using findViewById()
