toptobottom
Android Forum should be pro-active!
Let's stop
and do what is simply the right thing to do!
Let's stop
Shut down this forum? Could I send you a roll of aluminum foil? I can't believe the level of alarmism underlying that suggestion doesn't come without an accompanying level of paranoia that requires large quantities of tin foil application to assuage.
Procedures have all been announced regarding refunds. Future deals for new issue phones that aren't going to be out until next Spring are pretty much worthless as to their credibility at this time. If Samsung or your Carrier is going to entertain some compensatory rewards then I don't think anyone would need this thread to find that out.ironass two penn'orth, (2c worth)... I believe the forum should still be kept open as there are still things going on with refunds and offers on the Note7 and there may well be questions from former owners about this rapidly changing situation worldwide.
That's been overly done already. This forum is more than likely going to generate more pissing match commentary than anything else of value, while in turn making it burdensome on volunteer Moderators to have to closely monitor threads to referee them before they draw blood.What we should be politely doing, is guiding any of those that have not returned these potentially lethal devices, (currently around 35,000 worldwide), to cease using them and return them for a refund a.s.a.p as it is now abundantly clear that Samsung and the carriers are taking steps to stop their use and even make it illegal to own one, see, here.
Where'd you get that 35,000 figure from? I thought it would be at least 200,000.
What alarmism? You're mistating yourself as the N7 is at the stage of 'it never happened'! So basically there's no paranoia on anyone's part. The facts are real per the Manufacturer's statements, pleas and other actions not any member here. In other words, the writing is on the wall and everyone here has either been responsible or read it to those who cannot understand.Shut down this forum? Could I send you a roll of aluminum foil? I can't believe the level of alarmism underlying that suggestion doesn't come without an accompanying level of paranoia that requires large quantities of tin foil application to assuage.
If you desired to walk around your own home with an unpinned grenade then go right ahead, but I ask, Do you need a forum for that action?
I do own an N3 and each year follow this message board to help guide my decision-making as to whether I upgrade to the new model.You don't own a Note 7. Do you need to remain here to troll people who do, who are exchanging questions, answers and ideas regarding that? I can't see how you do.
FYI, I became an active member and contributor to this message board with many of the members on here since we all got excited about pre-ordering the HTC Droid Incredible. Therefore, I don't believe I troll and it is in my best interest to participate in these forums to help promote positive discussion for future models that are of benefit to the Note enthusiast. I admit there are times that I go off-topic to try and inject some humor which could be taken as steering things in a negative direction. Trolling? I think not! Opinionated member and participant - GUILTY!!!
